Can anyone who owns a Philips DVDR3545V/37 plays PAL disks? In the specs it says:
Video Disc Playback System: NTSC, PAL
I called their customer support because I cannot play PAL disk in my unit(disks are marked ALL regions). They said it won't play PAL, however in another post a user states his call to customer support told them it will play
PAL.
Thanks................
	As crazy as it sounds, the problem may be that it can't play PAL DVDs that are marked all regions. I have an old DVP-642 by Philips and it has that problem with commercial DVDs. I have a commercial DVD (NOT a bootleg, but a legit all regions release from Russia - I know I know, but it really is legit as it's a Russian movie from ruscico.com) that is PAL and all regions and my DVP-642 will not play it at all. It will play PAL DVDs with region codes without any problems and it will play PAL DVDs on DVD+/-R without region codes too. Why it is different for pressed DVDs, I don't know.
 I believe that all Philips DVD players are capable of playing PAL and NTSC DVDs and I know of no exceptions. If your disc is a commercial one, try ripping it and burning to DVD+/-RW and see if it plays.
	The product manual states is plays DVD's marked Region 1 and ALL. It is a ripped DVD+RW. It plays fine in my other Philips and LG DVD players.
 Thanks for the reply and info!
  Does Philips BDP3406/F7 play PAL DVDs on NTSC TV?By whachano in forum DVD & Blu-ray PlayersReplies: 22Last Post: 3rd Aug 2013, 00:37
  Philips DVDR3600 PAL to NTSC?By techiejustin in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Sep 2011, 20:30
  DVD players that play PAL & NTSC - do you need a PAL television?By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53
  my panasonic standalone dvd can't play pal dvds...but can play pal svcd'sBy stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46
  Philips DVP 642 (37A) dvd player -does it play PALBy Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Jun 2007, 00:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
