Hey!
I've got FRAPS 2.9.5 full version... But the problem is that it lags sometimes very much! from 55fps to 10fps!!! WUT!? And it can't be computer specs!!! I play on a resolution in 1280x1024. When I record 1280x720 so it gets to widescreen but it lags! Plzz help me!
It's your computer specs. For each recorded frame the computer has to copy the RGB data from the video card's frame buffer, compress it, and save it to the hard drive. At 1280x800 that's a lot of data and number crunching. And while that is going on the computer is running the game which consumes more CPU.
Try playing at 640x480 or some other small resolution (so there's much less work to do) and you'll see things pick up. -
Hmm.. I'll try and see if it works..Originally Posted by jagabo
Ah, okay. I wasn't sure.
But is it still compressing while it's capturing?
(okay, okay, I'll shut up, now...)If cameras add ten pounds, why would people want to eat them?
HD Cam Keep lagging
By Okay in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2011, 12:55 -
Using Aiptek HD Camcorder Lagging
By bearsbowl37 in forum Capturing and VCRReplies: 2Last Post: 3rd Nov 2008, 16:54 -
audio lagging off sync problem
By lindylex in forum Video ConversionReplies: 1Last Post: 4th Jul 2008, 20:01 -
ffd causing video lagging
By billsimard in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 13:19 -
Audio lagging behind in a VCD! Why?
By PunkMaister in forum Authoring (VCD/SVCD)Replies: 11Last Post: 13th Dec 2007, 20:03
I was basically asking if it did allow you to switch codecs.
