Hi im having a problem here, it took me about 3 hours to convert 2hours avi movie file into dvd format..although im using intel e7300@3.5ghz , seagate 500bg with read/write@100mbps. Im using the latest ulead video studio software. I noticed that during convertion, it used only 50% of cpu. Is there any other dvd maker software that used 100% of dual core cpu?![]()
a second hard drive would speed things up. instead of having to read/write to the same drive reading form on and writing to a second would inprove your throughput.
you might try the demo of convertxtodvd. if it's straight conversion without any editing it is pretty quick.--
I use FAVC for this type of conversion. HCEnc uses approx 80% of all CPUs installed. Similarly, I use agk with Divx Pro and get good utilisation of all CPUs (running on a quad core). I know that older versions of Xvid aren't multi-CPU aware, so you may have to upgrade Xvid if that is what you are using for agk. I would have thought the latest Ulead was multi-processor aware, but perhaps it isn't.
Read my blog here.
i used convertXtodvd 3 last night, it took me under 20mnts convertion for 2hours avi movie file into dvd. I was suprised. I noticed that it used the whole of my 2 gb RAM. Iv tried the new ulead x2 but it still slow >.> . guns1inger how long it usually took u to convert 2 hours of avi move file into dvd?
I use FAVC and it usually takes around 40 minutes for a 2 pass high quality encode with HCEnc. ConvertXtoDVD uses a faster encoder that does a single pass at arguably lower quality, hence it completed in around 20 minutes.
That said, FAVC also doesn't require all your ram to run, and leaves enough processing headroom to let me do other things at the same time.Read my blog here.
Convert a dvd into an AVI file(s) on a mac
By shonmader in forum MacReplies: 2Last Post: 15th Jun 2009, 09:34 -
What is the average time of ripping a dvd file to an AVI, or WMV
By ManhoefDream in forum Newbie / General discussionsReplies: 2Last Post: 4th Aug 2008, 15:49 -
Convert avi to dvd with date and time stamps
By Technicalychallenged in forum Newbie / General discussionsReplies: 0Last Post: 17th Dec 2007, 07:49 -
how can I convert dvd file on my computer to avi or a different file
By brew in forum Video ConversionReplies: 3Last Post: 19th Nov 2007, 20:21 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
