Thread: Firewire HDTV Vista Audio Sync Problems
  1. #1
    Member
    Jan 2008
    Posts
    32
    Ok so i have a Inspiron 1420 running Windows Vista Home Premium SP1 and i have been capturing HDTV stuff with my firewire and Scientific Atlanta 8240HDC stb. I cut the commercials out and convert to .mpeg2 using videoredo plus, then use Staxrip to encode to .avi but after its done encoding the audio starts off in sync but then slowly starts to get out of sync as the video progresses. I did not have this problem when using Windows XP SP2. So i have no idea what the problem is. I have no audio problems when encoding Standard Definition sources but for some reason all my HDTV encodes have been coming out not in sync with the video. Has anyone else ran into this problem before? If so please help! Thanks!
    I'm a MEGA Super Moderator Baldrick's Avatar
    Posts
    43,712
    You could first just try convert using something else like autogk or xvid4psp and see if it makes any difference.
    I guess you have checked so the mpeg2 created by videoredo is in sync?
    What version of staxrip? latest stable or beta?
    Member
    Jan 2008
    Posts
    32
    Quote Originally Posted by Baldrick
    the mpeg2 is in sync. Im using version StaxRip 1.1.1.0
    Member
    Jan 2008
    Posts
    32
    No one has the same problem?
  1. Audio Sync issues under Vista 64 and H264/AC3 MKV files at 1080p
    By tarrantm in forum Newbie / General discussions
    Last Post: 6th Jan 2009, 21:56
  2. audio sync problem with HDTV .m2t to mp4
    By avramd in forum ffmpegX general discussion
    Last Post: 2nd Dec 2008, 16:30
  3. Capturing HDTV with a Firewire and Capdvhs problems
    By superdud1400 in forum DVB / IPTV
    Last Post: 31st Aug 2008, 02:15
  4. Replies: 7
    Last Post: 2nd Nov 2007, 22:39
  5. Problems transfering audio in LP mode via FireWire
    By aguinsburg in forum Camcorders (DV/HDV/AVCHD/HD)
    Last Post: 26th Oct 2007, 16:55
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
