I noticed a lot of Users experiencing Vista's problem with Printer been "Offline" after a wake, none PC activity, or simply just Offline. In order to use the printer, it must add / reinstalled printer software to get it back "Online." I have this problem with the printer board before it solved by replaced it, but this probelm of "Offline" did not go away on one Vista machine.
Printer uses TCP/IP protocol via Netgear Gigabit N edition router, with Printer static IP reservation address.
Machine 1. Desktop Vista-32 Home --> Printer shows "Offline"
Machine 2. Laptop Vista-32 Home --> Printer ok "Online", however, it is inconsistent, one Vista works, but the not the other.
Machine 3. XP Pro --> Not an issue. Works fine.
Both Vista machines seems to have the latest vista update. No hotfix available to found to fix this problem. It a well known issue, this made me believe is Vista, file corrupted, registry? Not exactly sure.
Any suggestions how to fix the Vista Printer "Offline?"
Thanks.
I have several computers with Vista installed at work and at home and I have never experienced this problem. Are you using Vista printer drivers? If not, you can expect problems.
Try using the following commands:
NET STOP SPOOLER
NET START SPOOLER
This will set the operating sysm Print Spooler service. And reset the Offline status of all your printers.
Also may be executed as :
NET STOP "Print Spooler"
NET START "Print Spooler"
Good luckGeocoga
Continuing problem with "Offline Files" disconnecting
By Cornucopia in forum ComputerReplies: 5Last Post: 12th Apr 2012, 00:21 -
Tip: How to add "detele" and "up" buttons in Vista/7
By roma_turok in forum ComputerReplies: 1Last Post: 3rd Jul 2010, 15:54 -
Windows Movie Maker (Vista) and "clips"
By freshone in forum Newbie / General discussionsReplies: 1Last Post: 31st Mar 2009, 17:26 -
Remove "New" items fom right click in Vista ?
By scorps in forum ComputerReplies: 2Last Post: 16th Feb 2008, 12:28 -
Problem rebooting into Vista after "Safe Mode"
By RKelly in forum ComputerReplies: 1Last Post: 3rd Jan 2008, 23:31
