Those of you with capture cards, how long does it take (on an average).. to capture a 2 hour movie to vcd format?
Are you capturing to an Mpeg ? Then you'd probablt refer to a hardware encoder device (ie Dazzle).
Quite simply if it captures in VCD format, it'll take you 2 hours to capture a 2 hour movie....it's realtime encoding.....~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
which dazzle device is the best... yes i want to encode straight to mpeg
depends on your settings--just to give you an idea I capture Mpeg-1 352x240 @ 1.96 MBps with 224kbit/s audio and 45minutes takes 700MB or so. I don't like to re-encode or anything else but a dedicated person might be able to squeeze that down a bit. There are a hundred different ways of doing captures, you just have to find the one that suits your lifestyle
Is it OK to use 24p capture all the time?
By turk690 in forum EditingReplies: 9Last Post: 29th Aug 2011, 12:56 -
capture and watermark a video at the same time ?
By momo1984 in forum Video Streaming DownloadingReplies: 1Last Post: 4th Aug 2010, 21:15 -
first time dv capture ???
By cd090580 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 9th Nov 2007, 08:24 -
Capture time
By galehickey in forum Capturing and VCRReplies: 11Last Post: 2nd Jul 2007, 22:15 -
Capture in Mpg Real Time-Best settings?
By themaster1 in forum Video ConversionReplies: 3Last Post: 21st Jun 2007, 21:01
