Im trying to figure out a best encoding practice for taking .mov files encoded at bitrates anywhere from 15 -20 mbits/s
to an h264 version encoded down to a reasonable bitrate to push to custom flash player (progressive download).
I have found using QT Pro (h264.mov -> h264.mov) I can get decent results but would like to understand the possibilities of ffmpegx as being a better solution for encoding these things
Im really pretty new to all this video encoding stuff but a pretty competent flash developer.
I have tried to encode the same source .mov's using ffmpegx's mp4 h264 preset just scaled down the bitrate to 480 , audio 64. The results look great when played back in QT pro but passing off to my custom flash player Im getting.
NetStream.Play.StreamNotFound
could this be an issue with .mp4 extension? I was under the impression flash didnt care what the container was.
I have also read something regarding a moov atom that needs to be at front of stream but really have no idea what im talking about
any light shed would be greatly appreciated
thanks
im an idiot, file permissions weren't set correctly on video files. apparently amazon s3 server gives only read to owner upon upload. Once I set em 777 and all was good.
Thanks for the advice tho. I'll try it just to see if works and let you know.
AS it stands now the player can handle mov, mp4, and flv file types.
I wish I was more fluent in the encoding arcana. Eventually i suppose it will all make sense but the initial learning curve seems a bit steep. Thankfully I have this site for a resource
What form of h264 will VideoRedo h264 tvsuite accept?
By Asterra in forum Video ConversionReplies: 4Last Post: 12th Apr 2012, 14:22 -
Problems converting some xvid to h264 to append to another h264
By PlanetIndigo in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 15:13 -
Mov h264 to MP4/h264 Conversion
By Scooter_NJ in forum Video ConversionReplies: 2Last Post: 26th Mar 2009, 11:07 -
H264/AC3 (MKV) to H264/AAC (MP4) ?
By jccca in forum Video ConversionReplies: 10Last Post: 13th Dec 2008, 20:06 -
H264: Are there other h264 (AVCHD/VC-1) encoding command-line/CLI tools ??
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2008, 02:20
