Hello,
I just ripped a DVD using Shrink DVD, but it gave me about 94 files!!! 3 major 1GB files and some 90+ extras.
What I'd like to do is select the 3 main VOB files and add 6 or 7 smaller VOBs varying in size (from 54MB to 194MB), then burn one DVD that has my own selected files.
Any advise on how to do that is appreciated.
I also have one more request/question, which I'm not sure if it belongs in this section or not,
but here its is anyway: When I play the original DVD on my TV it takes up all the TV screen (looks kind of odd).
Is there a way now that I have ripped and extracted the VOB and IFO files to re-encode those files so that the the video resolution is like 352X240 or something like that...which can be displayed on TV w/o taking up the whole TV screen?
Thanks in advance!
-PM
Use the reauthoring mode in dvd shrink if you want to make a new dvd from various clips from a dvd. You can't do much from just vob files. http://www.dvdshrink.info/compilation.php .
Why does it look odd when it take up all the screen? You can reconvert with black borders but I don't see why as you will lose quality. Use for example xvid4psp, tmpgenc xpress, total video converter.
Best Software to Edit VOR & IFO Files from Panasonic RAM Disk & Arc
By JDex in forum Newbie / General discussionsReplies: 16Last Post: 30th Sep 2009, 06:55 -
Burn - VOB without IFO & BUP files?
By Miss Sherlock in forum Authoring (DVD)Replies: 25Last Post: 24th Aug 2009, 01:20 -
How do you make a DVD from only some VOB & IFO files?
By JoeBolden in forum DVD RippingReplies: 3Last Post: 12th Mar 2009, 01:12 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 08:31 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 14:38
