    Feb 2008
    Portugal
    Good evening
    I want to reinstall my Windows XP. Please tell me how to save the Favorites.
    Thank you.
    Cheers.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    If you mean the internet explorer or firefox favorites shortcuts than you use the import/export option in the browser you use most. Then that way you can get them for other browsers.
  3. Member wtsinnc's Avatar
    Nov 2006
    If you are going to do a full reinstall including wiping/formatting the drive you need to back up every file and folder containing any personal and unique data that you want to keep. For favorites, I use the built-in Windows backup utility, choose the option to select what I want to back up (which would in your case include favorites), make the selections and run the utility backing the chosen data to "My Documents". From there, I burn the backup to CD and use it to restore the data to the new installation.
    If you have never done this, Windows includes a primer on how to use the Backup and Restore Utility.
