  1. how do i strip audio to replace with new audio?
    Jan 2007
    Republic of Texas
    This answer will be as detailed as the information you've given in your question:
    Demux. Replace. Remux.
    Until we know source and format of audio and video, there's not much else to say.
  3. it is avi file
    Jan 2007
    Republic of Texas
    DV avi? (That would be a .wav audio stream.) Divx or Xvid Avi? (That would be either mp3 or ac3 audio.) There are different ways of dealing with different encoding types. "Avi" still doesn't say much, as it is only a container to the video and audio streams. Open the avi file in GSpot (freeware in the Tools section) to see what type of video (dv, xvid, divx, or uncompressed RGB) and audio (wav, mp3, or ac3) are found inside the avi container.
  5. what next is there a article i can to read to get a ideal from
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Originally Posted by lou41888
    it is avi file
    Use AviMUX GUI -- that's all it does.
    More complex editing, try AviDemux (no relation), or VirtualDub
  7. how do i add the new audio?
  8. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Same tools. They're all free. Install them and read the help and various guides.
