The slideshow made by the Windows Movie Maker is clear enough in a viewing screen, but it is not clear after I enlarge it to the full screen. How to set the Windows Movie Maker for optimizing the full screen viewing?
Hi, my current screen resolution is set maximum 1280 by 800 pixels. The Move Setting in the Windows Movie Maker is the default setting “Best quality for playback on my computer.” I saw the "Other settings." There are a lot of choices there. Is the "Video for local playback (2.1 Mbps NTSC)" the best setting for the computer viewing? If I want to burn it into a DVD disc, what setting should I select, by the way?Originally Posted by Baldrick
Basically, you can't take a small image and blow it up to full screen without it getting fuzzy or blocky. If you want a video that looks perfectly sharp when played back full screen you need to start with an image that is full screen -- 1280x800 in your case. If 1280x800 is impractical or unavailable you should use the largest source size you can.
WMM exists only so Microsoft can say Windows includes a video editing application. It doesn't really do anything useful. A lot like Windows' Paint program. At least use Windows Media Encoder which free but much more flexible.
Are your source images pictures from a digital camera? Frames captured from a video? Screen caps of text? Computer generated graphs and charts? -
Go to Papa John's website and download the extra profiles for WMM. They will improve the quality over the built-in profiles, and add some extra large profiles for bigger screens. Start here : http://www.papajohn.org/ and look under Save Movie -> Custom WMV Profiles.
I know the site is a mess to look at, but if you are going to use WMM it is one of the better ones to work your way through.Read my blog here.
I want to make a DVD photos slideshow (from still digital camera). I have tested a couple of video editing software. I feel the Windows Movie Maker is pretty easy and user friendly although it may lack some features. But, for the beginners, it is just the right tool for learning edit and making the first photos slideshow. I tested different settings. The “high quality video (NTSC)” has better viewing quality in the full screen but occupies less space. The “DV-AVI (NTSC)” viewing quality is worse than the “high quality video (NTSC).” I think I should select the “high quality video (NTSC)” for the computer viewing and emailing. Is it correct? I also wonder whether I can select the “high quality video (NTSC)” and then burn it into a DVD disc (by using the third party burning software) or I have to select the “DV-AVI (NTSC)" to burn the DVD? Does anyone know it?
I ran a little test, indeed High Quality Video NTSC WMV was sharper than DV-AVI (both were 720x480, 29.97 fps) when I started with some ~2000x1500 JPG images. Microsoft must do this intentionally because there is no reason for it.
You may find it much easier to deal with DV AVI than WMV when it comes to converting to MPEG2 for DVD.
You'd be much better off using something other than WMM.
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 18:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 16:43 -
Blank screen when playing video on 'full screen'
By RAYPEV in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2011, 20:40 -
Best Method to Convert for Full Screen Viewing
By Deter in forum Video ConversionReplies: 8Last Post: 23rd Nov 2009, 20:43 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23
