Ok I am looking to convert a dvd into mkv. I am looking for the best possibly quality and don't really care how long it takes or the size. I just need it to be compatible with my Popcorn media player.
Here are my questions:
- what is the best (maybe easiest) tool for this, and is there a guide for it?
- what settings should i follow to allow this to play on that media player
I am not apposed to using a one-click solution if that will be easiest and give me good quality. But I really do want to keep the quality for this one.
Any other suggestions would be appreciated.
Thanks.
Results 1 to 11 of 11
Xvid4psp, load the DVD(rip using DVD Fab Decrypter or use ANyDVD), choose mkv format, h264 video, copy audio(to keep ac3 or dts track). If you don't need a specific file size use Constant Quality/Quantizer h264 encoding mode.
You can also use megui, ripbot264, staxrip, automkv, fairuse wizard but I think xvid4psp is easiest.
But doesn't the popcorn hour support dvd isos? No quality loss....but I guess you want smaller file size? -
Popcorn hour does support the isos but they have to be on a USB drive or internal hard drive. I am using myIhome to stream from my PC. But currently that software doesn't support DVD ISO's.
You basically want AVC high@4.1 or lower. Most GUI's will have presets for "AVC Standalone" which corresponds to blu-ray players - this will be the same. It won't play if you have too many reference frames or b-frames.
So basically do all GUI's produce the same quality? So if I were to use any of the one's that Baldrick suggested, is my ouput going to be the same?
Thanks. -
They all use x264.exe as the back end - the GUI's are just front ends. If they use the same x264.exe version, and you enter the same settings they will give identical output.
some gui add filters, other .. no
so the output could not be identical
BHHHDConvertToX, AutoMen, AutoMKV Developer -
Does anyone one know which option in FairUse I should use to achieve what I am looking for? I am confused by H.264/AAC/MP4 or H.264/AC3/AVI??Originally Posted by Baldrick
Just curious as to which one will give me a compatible .mkv to play on the Popcorn.
Thanks. -
FairUse Wizard can't make mkv...just mp4 and avi. mp4 should work on your popcorn hour and is better for h264 but you can' keep the ac3 then.
edit: okey, you can make mkv so ignore this. I just checked the custom profiles.
Fairuse Wizard can make mkv
As far as his quality that may take some tinkering around till her finds what he wants
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
muxing .264 stream to .mkv, or to .mp4 first, an then to .mkv ?
By codemaster in forum Video ConversionReplies: 2Last Post: 20th Sep 2011, 21:50 -
MKV (H.264 and AAC) to mpeg2 (for DVD)
By Anonymous1 in forum Video ConversionReplies: 11Last Post: 2nd Sep 2011, 15:57 -
How to convert an h.264 MKV with softsubs to an h.264 MP4 with hardsubs.
By hawk16zz in forum User guidesReplies: 4Last Post: 27th Apr 2010, 12:41 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 10:25
