Hello,
I want to burn 2000 pictures in several slideshows, which are choosable with links in a self made menu (like from DVDLab). They should not be reduced to PAL or NTSC resolution, like many Slideshow-Softwares are offering, but in the maximum resolution the TV (on which I am looking them) is possible to display.
So I search a way to create menus and slideshows as I like, with effects and music, without reducing the quality of my pictures (at least 1920x1080, other TVs are calculating down)
Which is the best software and the best way to realize this?
Thank you for your help
Do you want it to play in standalone DVD Players? Then are you limited to dvd-video resolutions(720x480/720x576).
Yes I want it to play on a normal 3year old JVC DVD-Player without DivX Functionality and without functionality to read jpg directly from dvd (Data-DVD), so I am forced to build a correct DVD structure (I tried to burn directly as DVD-Rom, the disc was not readable by player)
And then its not possible to leave original resolution?
Is that a limitation of every dvd player? I think I saw some threads here that this is possible, but dont have the time and concentration to read them...
Another option may be a video game console like a ps3 or xbox 360 (the wii does not support high def resolutions).
I believe they should be capable of showing a picture at its native resolution. However it would not be likely to handle anything over 1920x1080 as that is the max for the game consoles.
Another option of course would be to connect your computer or laptop to the tv then you can show any picture you want.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Full motion menu creation software with templates?
By TVJunkieLI in forum Authoring (DVD)Replies: 2Last Post: 7th Apr 2011, 08:54 -
DVD (full menu structure) to swf or other mobile format
By DHracer in forum Authoring (DVD)Replies: 1Last Post: 24th Dec 2010, 17:46 -
How do I create a DVD menu for a slideshow project that I created?
By wsmitty in forum Newbie / General discussionsReplies: 2Last Post: 17th Jun 2009, 18:26 -
Best Authoring Program to create full custom menu
By quik_123 in forum Authoring (DVD)Replies: 12Last Post: 11th Oct 2008, 00:46 -
Full D1 menu and half-D1 video in DVDA 4
By itsme1 in forum Authoring (DVD)Replies: 3Last Post: 13th Jul 2007, 10:00
