Hi all, I'm new here so go easy on me
I've got a slight problem:
I'm trying to convert swf's to any iPhone/iPod compatible format but it just won't work.
I used to use a progam that I think was called magic swf2avi, but it had some flaws, and then I found SUPER, and last time I tried it it worked without a hitch. But tonight, when I try to convert stuff it's just giving me errors.
I'm trying to convert episodes of "weebl and bob" and "30 second bunnies" but it's failing miserably.
Super's won checking tells me I might have a lack of free space on my HD, but it works when I try to convert XviD avi's so I'm guessing that wouldnt be the cause.
Any ideas why it won't work?
Only SWFs with embedded FLV digital video streams or that actually are FLVs (sometimes, people rename the .flv files to .swf) can be converted with a digital video converter like SUPER. 'True' Shockwave Flash animation files can't be converted that way. Are you sure the file you're trying to convert is a digital video and not a Flash animation?
Newbie question about blu ray ripping and converting
By pete7769 in forum Blu-ray RippingReplies: 8Last Post: 12th Jan 2012, 17:02 -
Newbie question - capturing and converting from DV
By zaspa in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2011, 16:56 -
very newbie question about converting video.
By br9541 in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 23:34 -
problem converting swf created by jing capture
By surfmonkee in forum Video ConversionReplies: 2Last Post: 22nd Feb 2010, 05:33 -
Complete newbie question: Converting everything to AVI
By mariognome in forum Newbie / General discussionsReplies: 9Last Post: 20th Jan 2008, 14:57
