my old crt monitor display turn black sometimesbut if you push it on top or give it a tap
, the display will return to normal. if it is shaken then it will turn black again. i know i need to buy a new monitor soon but is there any solution aside from buying a new one? maybe i could open it tinker with it?
hacking the Net using typewriter :D
At the rate LCD monitors are inexpensive these days it's just as well to buy a new monitor. You can get a decent 19inch LCD for under $200.00. I suggest buying them at your local store instead of buying from a online retailer. Because most online retailers have a dead pixel policy. I think Newegg has a 8 dead pixel policy which means you'll have to have that many dead pixels before you can return it. If you go to a local store you have 14 days to return for Office Depot and other stores have similar policies. I have yet to see a local store carry a dead pixel policy.
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO DON'T DO IT - There is very high voltage DC - over 30,000 Volts - in the Picture Tube and Horizontal Flyback Transformer that can KILL you!!! There is also 110 volts AC in the power supply that may not kill you, but it will definitely hurt you!!Originally Posted by d_unbeliever
What you are describing is probably a loose or failing ground inside the chassis - I had a CRT monitor that went blank on me when I touched the front of the glass.
It's best to pick up a used monitor - they are very cheap, or even free - if you want to keep using a CRT monitor, but I would recommend getting an LCD monitor."I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
(NO MAN IS JUST A NUMBER)
be seeing you ( RIP Patrick McGoohan ) -
Just a few questions to try to isolate a power issue from a signal problem or a bios/window setting.
Is there a led light that goes green to yellow when this happens or does it just shut off?
When it goes from black to having a picture does it do it quickly and smoothly or do you hear a coil sound and it lights up slowly?
Have you checked your bios power saving settings and related windows options to see if any peripheral shut off or hibernate options are activated? -
ya im saving for LCD. but i can't seem to part with that old crt monitor it was my first hard earned monitor
the led light is still green.
it goes black quickly.sometimes i can see horizontal lines ======= across my monitor. when i tap it gently sometimes i goes back to normal.
i don't think its hibernating but i will check my bios later.
i opened it and dust it little bit yesterday. luckily didn't electricuted.
Ya i read somewhere that it is full of voltage so i was cautious. Even if it is unplugged?hacking the Net using typewriter :D -
I've seen about 20 of those in the dumpster since 2000...
If you're serious about video, you certainly shouldn't be using an old crt -
I was told by an old TV tech that there was enough voltage stored to kill you DAYS after the monitor had been unplugged. Have not thoroughly tested this.
We stopped repairing monitors several years ago as it was just not cost-effective. Have picked up several working 17" CRT for free or for $10.00 or less.
Blank CD
By Elevenius in forum Newbie / General discussionsReplies: 13Last Post: 20th Apr 2011, 03:37 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43 -
Blank Video
By dweezil2176 in forum Newbie / General discussionsReplies: 1Last Post: 10th Nov 2007, 20:49 -
Why Does My LCD Monitor Go Blank?
By MOVIEGEEK in forum ComputerReplies: 2Last Post: 15th Sep 2007, 22:17 -
Video Is Blank
By Potenza in forum Newbie / General discussionsReplies: 3Last Post: 8th May 2007, 19:59
