Ive recently DL'd some files that are in this format:
abcd.mpg.001 etc
no rars. no pars. is this someting that If Complete can be somehow extracted?
cheers and thanks!
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
if you have the mac version of winrar or equililent try opening the .001 file with it. the new type of rar files start with that extension. if it 's not a winrar type files then it's probably pr0n and they used hjsplit. i don't know of a mac version, but there might be one or you could try any concatenation software that does file joins.
thanks
its actually c0oking not p0rn!
one is Clearly Better Than the Other!
Its On the Plate.
Ill wait and see and look into your suggestions a little later
Much thankfullness Your wayMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
Use Split & Concat to join ("concatenate") the parts, when they're numbered like that.
Xvid4PSP 6.001 encoding options?
By vampypiano in forum Video ConversionReplies: 3Last Post: 10th Nov 2011, 14:54 -
how to open 001-002.zip
By pcb in forum Newbie / General discussionsReplies: 5Last Post: 11th Jan 2009, 20:53 -
batch joining multiple .001 files
By vitamine in forum EditingReplies: 8Last Post: 22nd Sep 2007, 16:57 -
What do I do with <filename>.avi.001 files?
By Hank Kinsley in forum Newbie / General discussionsReplies: 5Last Post: 26th Aug 2007, 06:25 -
Philips DVD963SA/001 firmware installation???
By stieven in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Aug 2007, 10:44
