    Aug 2008
    I was wondering how long of a movie can you fit onto a DVD with a bitrate of 8.0 mbps? I currently use Sony Vegas 7.0 and Sony DVD Architect 4.0. I normally use their usual DVD preset and I think the settings are usually around 6.0 mbps. Should I export at a higher bitrate like 8.0 mbps? What is the norm? Thanks.
    Aug 2008
    By the way, I normally burn movies to a single layer DVD.
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    https://www.videohelp.com/tools/VideoHelp_Bitrate_calculator
    That link is for a bitrate calculator. You can use it to judge how much can fit on a dvd for a given bitrate.
    FYI there is an edit button on your post so you can edit your original post instead of posting again
