Precisely why notebooks and laptops with their single internal HDDs can NEVER be optimal for NLE.The reason DV capture to an external USB2 drive is even more risky than capture to the single internal drive is the USB disk controller is a moderate CPU intensive software process that needs to operate continuously during the transfer. Any other OS or application processes can cause interruption of data flow to the external USB2 drive.
Results 31 to 33 of 33
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
DV over IEEE-1394 is a real time data stream rather than a file transfer. As such there exist none of the resend data packet provisions found in file copies or ethernet file transfers. If the computer can't keep up for whatever reason, pixels, lines or fields get dropped. Once the stream is captured to a file, further copies can be made without data loss. Things just slow down while data is resent.Originally Posted by turk690
Laptops have disk storage compromise but still can be used for NLE. They are generally slower and lack capability for multiple internal disk drives. USB2 and Firewire require software drivers. A better solution is hardware based eSATA for the second drive if you can find that on a performance laptop.
The other typical laptop weakness is the display chipset. Make sure it is HD capable if you intend to edit HD. Also look for digital audio support to S/PDIF output connectors.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Yeah, I figured it wasn't quite up to the spec of the original. As long as the battery lasts long enough for me to transfer a whole tape, I should be OK I guess..Originally Posted by edDV
Al.
Capturing HDV Tapes using a DV Camcorder
By Raz1 in forum Capturing and VCRReplies: 6Last Post: 18th May 2011, 16:49 -
8mm to Digital - Capturing w/ DV Camcorder
By tripecac in forum Capturing and VCRReplies: 61Last Post: 9th Jul 2008, 19:51 -
Capturing from DV Camcorder
By m baqar in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2008, 00:16 -
Does capturing with a camcorder really damage it?
By IL_video in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 22nd Nov 2007, 10:31 -
Capturing from camcorder
By Confused Chimp in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 14:09
