When converting frame size from Pal to NTFC, how do you decide on what compatible NTFC frame size to use?
For example, say you have a Pal video at 352 x 288 at 29.97 frames/sec, would you convert it to the closest NTFC frame size which would be 352 x 240 or could you choose any compatible NTFC format like.
352 x 480
704 x 480
720 x 480.
	It is NTSC.
 PAL should be 352x288 at 25fps not 29.97fps
 352x288 usually has an aspect ratio of 4:3 with non-square pixels.
 Equivalent for NTSC is 352x240. If you expand size 2x on the vertical and horizontal axies you get 704x480.
 352x480 is usually used for interlaced video.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
  ABBA inducted in Rock & Roll Hall of FameBy deadrats in forum Off topicReplies: 3Last Post: 20th Dec 2009, 16:52
  Which would be the better quality????....Cant decideBy DrRaven in forum Newbie / General discussionsReplies: 13Last Post: 27th Jul 2009, 23:09
  How do I decide when nobody seems to be able to use their camcorder?By Steve F. in forum Newbie / General discussionsReplies: 9Last Post: 27th Feb 2009, 00:05
  h.264 digital format to PAL, SECAM, NTFC formats in DirectShow ?By manzoor505 in forum ProgrammingReplies: 1Last Post: 8th Dec 2007, 09:28
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
