In order to get at least a rough correct brightness level, I'm using Sony Vegas 8.0, open a new project and drop the SMPTE Bars test pattern onto the timeline. I then enable the external monitor which is firewire to my DV camera, and then S-Video out from the camera to a regular samsung TV. Can I use this setup and use the pluge bars procedure (adjust so that left two bars have no difference and the third bar is only slightly lighter) to get a roughly correct black level?
Yes that is what I do routinely. If you want similar for white level try the Belle Nuit DV color bar available as a tiff.Originally Posted by sdsumike619
http://www.belle-nuit.com/testchart.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Calibrating luminance levels/color for capture from VHS
By Cherbette in forum Capturing and VCRReplies: 188Last Post: 29th Sep 2011, 21:18 -
Recommendations for calibrating a westinghouse lcd hdtv?
By yoda313 in forum DVB / IPTVReplies: 30Last Post: 16th May 2011, 15:12 -
Calibrating Studio Monitor....
By bsuska in forum Newbie / General discussionsReplies: 0Last Post: 13th Dec 2010, 10:31 -
Calibrating a monitor
By OldMedia in forum DVB / IPTVReplies: 8Last Post: 2nd Nov 2010, 19:10 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43
