    Nov 2008
    I'm trying to convert MKV to DVD using FAVC. I do have .NET Framework and Avisynth 2.58 installed. Everything when I clicked "Generate DVD" button. The analysis window shows some error message as in the picture and then it freezes. After I close the window it will pop up another message saying FAVC is unable to process the following files. Please help.....Thanks.
    Can you play the mkv without any problems?
    Or else try DVD Flick or ConvertXtoDVD.
    Nov 2008
    I have no prolem playing the video with KMplayer. I was able to use ConvertXtoDVD but because the size is too big it requires double layered DVDs. Then I tried MKV2DVD it worked but the screen options are only either 4:3 or 16:9. I chose the latter and the video was squeezed by two hugh black strips. I haven't tried DVD Flick.
