I own a HDR-HC3E and have captured all my tapes using HDVSplit. I get m2t files which I can play on my computer using VLC, but I have not been able to make Media Player to view my videos.
I like to capture all my footage to harddrive using HDVSplit and be able to view it on my 50" plasma in the living room. If possible I would like to do this without having to re-encode to a different format. That takes time and possible introduces loss in quality. It would also take more harddrive space as I like to keep the native files for editing later with no quality loss.
I also tried to install HDTV Pump Filter 1.0.7 to see if I could play my files in Media Player, but no luck. I get some sound and a still picture every now and then, but it is useless.
If you have any suggestion I would appreciate it. Even if I can't use my native m2t files it would be of help if you tell me the best and most efficient workflow to get high quality playable files using server application as Windows Media Center or similar.
As far as I know the 360 can't handle m2t's directly. Also Media Center doesn't handle non wmv files vary well without registry hacking.
Your best bet would be to get tversity and stream them that way. I don't remember if you can stream unmodified m2t's directly. You may be forced to encode them to mp4 before streaming......Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Problem editing dvr-ms files from windows media center
By justinstrack in forum EditingReplies: 4Last Post: 2nd Jun 2009, 09:29 -
Dual tuner recording = split files in Windows Media Center Vista
By yoda313 in forum Media Center PC / MediaCentersReplies: 9Last Post: 14th Jan 2009, 02:10 -
xbox360 & HP x280n as Vista Media Center Extenders, help me?
By nemloc in forum Media Center PC / MediaCentersReplies: 3Last Post: 5th Jan 2009, 17:18 -
Windows Media Center can't burn its own files? (Vista Premium edition)
By yoda313 in forum Media Center PC / MediaCentersReplies: 5Last Post: 7th Apr 2008, 16:44 -
Windows Media Center Xbox360
By rwheeler in forum DVD RippingReplies: 1Last Post: 25th Jun 2007, 15:04
