Okay, I have a SVCD. The original bin file, which, alas, I no longer have, was 804 Mb. Now I want to make a copy of the SVCD. I figured it'd be just as easy as copying a VCD, which I've done countless times without problems, but apparently it's not that simple. Using Nero's copy CD option doesn't work. Neither does using VCDGear to try and make a .bin file of the mpg file (that little trick only works with VCD, I guess?), and saving the mpg file to the HD and burning that as SVCD doesn't work, either.
Any suggestions would be much appreciated. Oh, and yes, I use a 80 mins/700 Mb CD, so that can't be the problem. ;-)
Results 1 to 16 of 16
Think i have the same Problem:
(Filesize ist *not* the matter)
Got an Big Holydaymovie (4 CDS) as *.bin and burnd it via Nero.
Very Well.
Running well, perfect quality, great SVCD.
Deleted the Bins (only 8 Gig HD)
A friend of mine asked me if i could make a copy for him and...
Nero complains reading:
"invalid track information" (!) (cant remember exact phrase)
My solution would be:
Copy avseq01.dat do HD, rename to any.mpg, and create another
SVCD via Nero.(will Nero recode again?)
OR:
Copy all to HD and burn...
No think, that could possibly cause Problems with Joliett/ISO
Filenames / Conversions.
Somebody knows more handy Solutions ? -
Originally Posted by CrisOfSox
In any case, thanks very much for your help, both of you. :) -
Right theres not much different between dat and mpg.
I ask myself if there was some Copy Protection
in the cue/bin Combi ?
I still wonder how Nero can burn the bin, but cant
copy the Result... -
Originally Posted by dallista
No Recoding necessary.
"There are no silly Questions, only silly answers..."
Create a new SVCD Project with Nero and pull the mpg into it.
I'll try this after work... -
I had the same problem with copying SVCD's I made from home videos. The only way I've gotten it to work flawlessly is to choose Image Recorder in Nero and burn an image of the disc in Nero's .nrg format. Then throw in a blank, choose Burn Image, select your .nrg and burn it. This has worked for me every time...YMMV.
Hope this helps,
Guardian -
ACK that does it.
But seems i am to dumb to create an ISO(Image) with Nero.
Did it with WinOnCD, sometimes a readerror at start, after retrying
it works.
So do an Image, burn from Image -> Disk ready...
It works dut i dont understand completly why...
:wink: -
Originally Posted by Guardian
Edit: Okay... Creating an image file turns out to work fine. BUT now there's a problem that I cannot burn the .nrg file. Nero complains there's not enough space on the CD-ROM disc to burn the file to, which I'm guessing has something to do with the fact that the file is over 800 Mb. That makes sense, the original .bin file is about 805 Mb, I think, but I could fit that on a 700 MB/80 min CD fine, as SVCD.
So now what? :-( -
OK. Lemme see if I understand you...
You have an SVCD that works fine in your player. It's burned to an 800MB CDR and you're wanting to copy that to another 800MB CDR, correct?
Guardian -
See my reply to topic http://www.vcdhelp.com/phpBB/viewtopic.php?t=79333. It's worth seeing it, while there exists a program that copy's everything !
Dallista,
I'm at a loss. You're at the point I was at when trying to do a simple CD to CD copy and it wouldn't go. That's when I tried the image recorder trick and it's worked without fail for me.
Seems to me that it should be able to write to an identical-capacity medium without any hassle, but hey, I just do what my computer tells me to do...
hehehe
Sorry I couldn't be of more help.
Regards,
Guardian -
:-( Thanks for the help, anyway. I'm at a loss, myself. I gave the CDs to a friend, whose husband is more of an expert in this sort of thing than me, and hopefully he'll be able to figure it out. I'm keeping my fingers crossed, and otherwise I'll give that CD clone thing a try when I have the CDs back. ;-)
[/quote]
One last resort if you can't get the disc to copy...
If the SVCD works in your player, dub it off to a VCR and then reencode. I've only had to do this once (before I tried copying to an .nrg file) and I lost a little quality, but it did work...
Guardian
svcd will not launch.
By hawkwind in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 17th Jan 2009, 18:09 -
Procoder SVCD
By kippard in forum Authoring (VCD/SVCD)Replies: 7Last Post: 17th Dec 2008, 10:51 -
Svcd Burning
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 16th Apr 2008, 08:25 -
How do I split a SVCD
By VoXiSo in forum EditingReplies: 1Last Post: 4th Feb 2008, 15:14 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
