  1. Hi All
    i have a Sony RDR-HX720
    i would like to buy a nice surround sound system which i can use it along with the Sony Recorder
    I know there are HTB which comes as a package
    as i was interested in the recorder i forgot about the surround sound
    Let me know something i could use along with this recorder.
    Abdul
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    I would stick with Sony personally. I have a 5.1 fiber optic surround from around '01 or '02 I think and it still works just fine. It's a non-hdmi model though.
    I am not sure what type of system the RDR is but I'd recommend looking for a surround with HDMI inputs. Even though the specs aren't finalized yet they may be backwards compatible.....
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You are not limited to anything in particular. Any system or components that you want to use will work.
    Google is your Friend
    The RDR-HX720 is a DVD/HDD recorder. SD, no upscaling, so no HDMI (similar to the RDR-HX510 which I own). It has coaxial digital audio out, so should have no problem with current and previous gen audio receivers.
