im trying to load my media player with some of my dvds using dvd decryptor and dvd shrink when i try to just get just episodes,will play on PC but when i go into dvdshrink the wrong values are there any ideas thanks
Results 1 to 10 of 10
Describe exactly how you are ripping and what values in DVD SHrink?
And you might have to use DVDFAb Decrypter or ANyDVD to rip newer DVDs. -
But you decrypted using DVDDecrypter's File Mode, right? Separate the episodes from the beginning by decrypting in IFO Mode, each episode to its own folder, and then load the IFO. If that doesn't do it, then fix the delay. That's often easier than messing around with it too much.
Well, here's one way to find and fix the delay. This assumes a constant delay - it's off by the same amount all the way through:
Open the AVI in Media Player Classic. Right-click the screen and go Options->Internal Filters->Audio Switcher and make sure the "Enable built-in audio switcher filter" box is checked. You'll only have to do this once. If doing it for the first time, then hit "OK", close MPC and reopen it. Play the AVI in it and use the + or - buttons on the right side of your keyboard to add in a positive or negative delay. A negative delay causes the audio to play earlier. 1000ms=1 second. If you have trouble synching to lips moving, try and find a sharp noise like a door slamming or a gunshot and synch to that. It shows the amount of delay applied in the bottom left of the player. Once you get it the way you like, remember that figure and close MPC.
Now open the AVI in VDubMod, clicking "No" to any messages about VBR audio. Set Video->Direct Stream Copy. Go Streams->Stream List->Right-click the audio stream->Interleaving->Audio Skew Correction->Delay Audio Track By, and fill in the correct amount. "OK" back to the main screen and File->Save As, give it a different name, wait a minute or so and test it out. -
Hehe, if it seemed to work in MPC but not after you set the same delay in VDubMod then yes, you must be doing something wrong somewhere. I couldn't tell you exactly what, though.
With a +1050ms delay, you're saying that originally, before changing it, the AVI has the sound playing just over a second before the video. By the way, this points to an improper decrypt, probably a bunch of black frames before the real video episode began, and these black fames, probably a separate cell a second or so long, had no audio of their own.
You should still be able to get it right, though. Take the "finished" AVI with the changed but still incorrect delay and figure out the delay again and then adjust in VDubMod. You shouldn't really have to do that, though.
Ripping problem with Windows Media Player 11
By singjai in forum AudioReplies: 10Last Post: 8th Sep 2011, 14:42 -
Ripping DVD with sub to be played on media player.
By hanugro in forum DVD RippingReplies: 4Last Post: 12th Feb 2010, 07:10 -
problems ripping to Media Player ?!
By paulpeople2476 in forum Media Center PC / MediaCentersReplies: 3Last Post: 17th Jun 2009, 11:37 -
Ripping tv episodes from dvd to ipod?
By Steph-x in forum DVD RippingReplies: 3Last Post: 27th Jun 2008, 14:15 -
help with ripping the individual episodes from the dvd and converting them
By dvdrburner in forum DVD RippingReplies: 1Last Post: 22nd Aug 2007, 08:14
