Hi, I'm first time here so not where it goes but it seems that there's no dedicated forum for this, so...
I bought recently a home theater system which has LG HT963PA DVD player (regional code 1). At the same time I have some DVD's from from 2 and 5 regional zones. Question - how do I make this player play these disks?![]()
Results 1 to 9 of 9
A region hack also does NOT guarantee that you will be able to play these discs.Originally Posted by cwwmbm
A region hack is only half of the battle. You will most likely encounter the dreaded
NTSC/PAL format problem as well...which is NOT the same as region coding. -
Now that sounds awesomeOriginally Posted by hech54
Is there any way to bypass this problem?
Actually, don't DVD rippers usually make the DVDs region-free when you rip them?
If cameras add ten pounds, why would people want to eat them? -
Sometimes if you ask the dealers who sold it they can give you the code under the counter, so to speak.Originally Posted by cwwmbm
Yep, like DVDFAb Decrypter, DVD SHrink , DVD Decrypter.Originally Posted by Ai Haibara
Breaking DVD up into chapters
By yznf in forum DVD RippingReplies: 7Last Post: 22nd Jul 2008, 12:53 -
SONY DVP S 9000 es free reginal code
By pony728 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 29th Jan 2008, 09:34 -
Keep breaking my DVD players
By Buckarooo in forum Newbie / General discussionsReplies: 6Last Post: 15th Dec 2007, 17:37 -
Please Help! DVD-R disc are freezing/breaking up and pixelating.
By elove in forum MediaReplies: 19Last Post: 19th Sep 2007, 10:02 -
editing DVD audio without breaking menus
By nbi in forum Authoring (DVD)Replies: 9Last Post: 10th Aug 2007, 14:02
