Hi,
I have a question on encoding my videos scripts. I filmed a number of race seqments at night using digital camera, saved in mov format. The original rate was 4000 at 30fps. I then wrote some avisynth scripts to combine the individual takes of the races to make one long race, I then run it through a degrain filter and then smoothd filter to give it a nicer picture. I then use FAVC to encode the video at best quality, but not sure what to set the bit rate and how to get the best results. The last one I did I noticed some blockiness in the night sky and in a few other scenes, I am thinking this is from too low of a bit rate, am I right on this? If not, then what are the best settings using the hc encoder in FAVC? IF I am right what are my options..
Thanks for any advice as I am getting confused on this the more I read...
Probably because of bitrate. What hcencoder settings are you using? 2-pass? 1-pass? or constant quality/quantizer moder?
I guess your goal is to make a DVD? Then try use highest possible bitrate((around 8Mbit) or best constant quantizer/quality mode and see how it looks like. -
Hello,
I am using the default best quality settings, which are 8000 bitrate, 2 pass, quantizer. It had to lower the bit rate down to 6500 to get it to fit onto 1 dvd. Would it be better to have it on 2 dvds or a dvd dual layer burned done at a higher bit rate? Is constant rate better then the best default settings?
Hope to hear from you soon and thanks for the help.. -
Hello,
One mistake on previous message, I am using 2 pass variable rate bitrate and not constant. If I go to Constant, what should I set the constant quantilization to, it goes from 1 to 31.
Thanks again for the help.. -
1 is best, 31 is worst with Xvid, not sure about MPEG. But with single pass Quantizer mode, you don't have much control of the encoded filesize, if that's a problem. But it will be much quicker than two pass mode. You could try a representative clip of about 5 minutes long to test different Quantizer numbers to see how it looks. I would start with 2 and you can use that to figure out the total size your files will be from that.
Some encoding questions
By inject0r in forum Newbie / General discussionsReplies: 14Last Post: 30th Apr 2012, 11:47 -
Handbrake Encoding Questions
By x22 in forum DVD RippingReplies: 1Last Post: 19th Oct 2011, 21:41 -
Encoding noob questions
By Frakit in forum Blu-ray RippingReplies: 8Last Post: 3rd Jul 2010, 02:08 -
A few questions on Anamorphic encoding
By scubasam in forum Newbie / General discussionsReplies: 10Last Post: 31st Mar 2010, 22:04 -
a few encoding questions
By henhao in forum Newbie / General discussionsReplies: 3Last Post: 11th Apr 2009, 18:57
