Hi, anybody knows how to rip the subtitles from DVD to SVCD? I dont need them to switch on and off (my Pioneer DV-525 doesn't support that), just want them to be displayed (encoded to movie) while playing.
Easiest way ?
Use DVDx or XMpeg with the CCE codec.
Quality is like TMPGenc, it's faster and suports subtitles with just a setting.
Only contra is that it doesn't have as much settings as TMPGenc and it's not free (atleast CCE costs a whole lot of $$).
Greetz
Mars-L -
DVDx 1.6 will rip a DVD with the subtitle of your choice (if available) if you check a box. I've only done it on one DVD but it worked great!
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Thanks, I'll try. And what if I want to put subtitles to DivX file encoded to MPEG2? I have the video file, the subtitle text file (text and time codes). Is there a utility that can put subtitles automatically where they should be?
if i recall vobsub will accept .srt & .ssa format subs. use vobsub with virtualdub, aviutil, avisynth or graphedit
You may want to try the all-in-one solutions.
DVD2SVCD will do SVCD, CVD, and Permanent subtitles. It uses avisynth for the permanent subs.
Gordian Knot for your DivX w/Subtitles.
Both are awesome programs and will give you the best results! -
1) the vobsub/virtual dub combination seems good...only failed me one time. vobsub filter (add subs) in virtual dub and frameserve to tmpgenc...
2) use flaskmpeg and frameserve to tmpgenc with avisynth. flaskmpegn allows you to add subs
Trouble ripping DVD with subtitles
By stig in forum DVD RippingReplies: 9Last Post: 22nd Feb 2012, 05:08 -
Subtitles ripping issues
By neo179neo in forum Blu-ray RippingReplies: 6Last Post: 7th May 2011, 06:24 -
m2ts ripping and forcing subtitles-how?
By bigshotceo in forum Blu-ray RippingReplies: 0Last Post: 19th Mar 2011, 10:02 -
Ripping Foreign Subtitles in my PC
By devilcoelhodog in forum SubtitleReplies: 3Last Post: 23rd Feb 2009, 09:28 -
ripping subtitles from a movie?
By VanZan in forum SubtitleReplies: 3Last Post: 17th Aug 2007, 16:46
