I have a Sony DCR-TRV22 camcorder that I am able to capture video thru Windows MovieMaker via its USB driver. I have the following questions:
1. I have tried to use WinDV but get the error message 'Can't find DV output pin'. I only want to use WinDV to capture but this error (which appears to apply only to sending video to the camcorder) will not allow it. Is there a workaround?
2. What alternative capture software (free) is available that I should check out? Would it be better than MovieMaker?
3. What parameters should I use for capturing, e.g., frame speed, compression (YUY2?), etc.?
4. What is the best free video editing software that I can download?
Thanks in advance.
Fred Berry
I too have the TRV22 camcorder. You definately want to use the firewire cable with it, not the USB.
The reason you get the error message, 'Can't find DV output pin', is because you did not connect your cam to firewire.
-vhelp 4921 -
USB gets you CIF 352x240 single field only. This is intended for Netmeeting or other low quality streaming.
Use Firewire if you want quality transfer.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Sony DCR-PC 110 for S-VHS to DV capture
By peg in forum Capturing and VCRReplies: 1Last Post: 14th Apr 2012, 14:44 -
How do i capture with Sony DCR-TRV520 and play the avi on my WDTV?
By video_noob in forum Capturing and VCRReplies: 20Last Post: 10th Aug 2010, 12:52 -
Windows 7 won't capture Sony DCR-TRV340
By lifespeed in forum Capturing and VCRReplies: 2Last Post: 3rd Oct 2009, 14:17 -
Sony dcr h26 - how to capture contents of miniDV
By siopawman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 3rd May 2008, 04:16 -
Live Video Streaming using Sony DCR TRV22 and IBM T42 laptop
By MESP2005 in forum Capturing and VCRReplies: 3Last Post: 16th Mar 2008, 06:52
