Results 1 to 11 of 11
    Sep 2006
    I have had a new hard drive installed so I have been downloading the Microsoft updates for WINDOWS. Usually it is no problem.
    But now the downloaded updates refuse to install into my PC. What do I do?
    ryan kendall
  2. If you search with Google there are sites that can help. There are files that may need to be re-registered. I am at home and don't have the list at hand, sorry.
    There is also a help section on www.microsoft.com about this problem that has fixes. I'd try this first. It is actually a fairly common problem if a WinXP SP2 disc is used to do a repair install.
    Good Luck
  3. Download and use Dial-a-fix.
    This little piece of software will automate the process of fixing Windows Updates.
    Wiki page and download links:
    http://wiki.lunarsoft.net/wiki/Dial-a-fix#Download_Dial-a-fix
    Alt Download:
    http://www.softpedia.com/progDownload/Dial-a-fix-Download-27328.html
    Sep 2006
    Hello and thanks for the Tips.
    This freeware Dial - A - Fix I downloaded. It looks great. Please assume I am a computer geek of the lowest rank and tell me how to fix this problem "Microsoft Updates will easily download but wont install on my PC." in a manner for the compleate idiot. (me)
    Mar 2004
    Hello,
    WU/WUAU
    open up dial-a-fix. Tick the box that says WU/WUAU. click the button "GO" on the bottom of the program. DON'T DO FLUSH SOFTWAREDISTRIBUTION. That is another option that we might not need in your case. Once dial-a-fix is finished. Go ahead and reboot and try and reinstall your updates.
    Let us know of your progress.
    -PB
    Sep 2006
    Hello.
    I did just what you said. then I rebooted.
    As if by magic, the seventeen (17) Microsoft XP & Microsoft Office 2007 upgrades installed....and smoothly, too.
    I rebooted, again. The computer ran great with no error messages. Thanks! Great!
    bryan
    Mar 2004
    Glad to be of service.
    -PB
  8. Hang on to Dial-a-fix. You may very well have the same issue again. I've got a PC at work that I have to run Dial-a-fix on every month. WU keeps breaking and I can't for the life of me figure out why.
    Jan 2006
    Are any error messages given? Once I fixed this problem when it was encountered by going to Microsoft site and doing a search for the exact error message given.
  10. It does leave some sort of error in the event log if I'm not mistaken. It wasn't easy to find anything on MS website based on those messages though.
    Jan 2006
    In the instance I had it showed error message on PC screen such as "Access is denied. Updates not completely installed." I had to uninstall the incomplete updates install and find cause via search for error message on MS site. I suspect it'll be harder to determine cause if you aren't getting similar messages to popup.
