Really need your help!!!!! My in-laws got JVS HD camera and were recording video during vacation. Beside the pain of JVS proprietary format which I had to convert to mpg, now I have 290 files which I need to burn on DVD to watch on TV. I tried using DVD Flick, but it has a limit of only 99 files. Is there anyway around it with another program? Please advice what I should do to make it playable on a regular DVD. Thanks!!!!!!!
We will assume that they are less than 4.3gb in total. (size of one DVD single layer)
U could always join them all together using an editor or simple joiner, then the number of files is a non issue.
If you want to jump to one place in particular, then set chapter points. -
Actually, the size is over 7GB (for DL DVD), but I can split files in half to fit a regular DVD. What editor or simple joiner would you recommend me?
TMPGenc will join mpg and its free.
Another I used is EasyVideoJoiner ...it's got a free trial (but I think the trial only joins 5 clips at a time)
As far as the size I was only asking if it would fit on a DVD (single or double makes no difference) if you joined them all together.
Burning several mpg files straight to a DVD compliant disk...
By vonsworld in forum Authoring (DVD)Replies: 2Last Post: 5th Dec 2010, 06:25 -
Burning mpg files
By batke in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2009, 22:18 -
burning a DVD from MPG files
By nick177th in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2007, 17:36 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56 -
How do I brighten dark video (mpg) files before burning to dvd?
By denise4gb in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2007, 22:17
