Hi everyone,
I'm trying to decide between the ADVC-55 and the ADVC-110 for converting my analog VHS tapes. Other than the output and locked audio capability of the 110, is there any other reason to choose the 110 over the 55? I don't plan using the output feature, but if the locked audio will ensure that everything stays in sync I will probably go with the 110. Just wondering if anyone has any personal experience with that and whether or not the locked audio makes much of a difference. I know someone who is selling their ADVC-55 and an unused copy of EDIUS Neo for a decent price (from what I can tell), and second hand 110's seem to be only a little bit more expensive. Also, is EDIUS Neo a decent software package or is it rather limited compared to the pro version? I was planning on using Windows Movie Maker and then using some other software to author DVD's - is EDIUS Neo capable of doing all of that?
Thanks!
If I recall the 55 is really the same thing as the 110, but without the conversion of digital to analog. The locked audio feature they advertise is standard on all models. If you don't need the output I'd say go with the 55/Edius package. That gives you an entry level NLE.
I've been using an ADVC100 for about 4 years now and I couldn't happier.
I can't comment on the Edius software as I've never used it. If you haven't checked it out yet the Edius info page might help you decide if it is of use to you. http://desktop.thomsongrassvalley.com/products/EDIUSNeo/index.php -
I use to use my advc 100 but i dont anymore. I use a standard dvd recorder and use rewriteable media
I've been using the advc100 for over 4 years and I'm happy with it. One thing I like is that it can handle copy protection, which comes in handy.
I too am happy with the 100/110.
I've used the 55 but can't recall if it supports locked audio (good for long dubs) or if it has the handy 0.0/7.5 IRE switch (saves hours of levels filtering).
The 100/110 has the ability to show WYSIWYG from the output which IMO is invaluable. This depends on edit software that supports real time preview out IEEE-1394.
The other factor favoring the 100/110 is much higher resale value. If you buy one used, you can probably get your money back when you sell.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Canopus ADVC 110 - Capturing in Windowbox
By nharikrishna in forum Capturing and VCRReplies: 6Last Post: 28th Oct 2011, 05:50 -
Macrovision and Canopus ADVC 110
By nikgelfi in forum Capturing and VCRReplies: 2Last Post: 13th Apr 2011, 17:09 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Canopus ADVC 110 Possible problem?
By Drexter in forum Capturing and VCRReplies: 4Last Post: 20th Feb 2010, 22:10 -
Canopus ADVC 110 video out question
By Darkestred in forum Capturing and VCRReplies: 5Last Post: 3rd Aug 2007, 23:12
