Hi,
I searched quite a while in the forum and did not find an answer. I am quite new to this topic so pls bear with me.
As the PS3 does not seem to play hd-mkv files and also I did not manage to get the streaming of mkv files to the PS3 working, I use mkv2vob to change the hd-mkv files into avi files. This works pretty fine for the video and 1 language.
My problem is that i can not find a way to have more than one language, or all the languages available in the mkv file ending up in the avi file.
Does anybody know a tool, or more generally spoken "a way" which allows me to either
-converting mkv with 2 languages into PS3 compatible file (keeping the 2 languages)
-use the mkv file directly on the PS3 (which would allow to switch between the languages)
-stream the mkv file to the ps3 (which would allow to switch between the languages)
I cannot beleave that storing two seperate versions of a hd-movie is necessary to be able to watch it in two languages.
pls help.
And007
Results 1 to 1 of 1
mpg file won't play on PS3 after running mkv2vob
By drthundr in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2011, 13:55 -
mkv with 2 languages into PS3 compatible file using mkv2vob
By fairwind in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2009, 16:11 -
By fairwind in forum AudioReplies: 1Last Post: 22nd Jan 2009, 16:10 -
mkv, mkv2vob,yamb and the PS3
By sulimo in forum Video ConversionReplies: 1Last Post: 31st Oct 2008, 04:22 -
.mkv conversion with either gotsent of mkv2vob, PS3 issue.
By astyanax in forum Video ConversionReplies: 6Last Post: 29th May 2008, 13:34
