Dead? No, you may still be able to recover data with the right software.
Results 31 to 38 of 38
The drive is recognized by the system, so it is not completely dead. If you are resigned to the fact that this drive is dead and the files are unrecoverable, then it could not hurt to try and reformat the disk completely. You may still be able to use it afterward.
"I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
(NO MAN IS JUST A NUMBER)
be seeing you ( RIP Patrick McGoohan ) -
Jagabo is there any software you would recommend using?
Number Six I would do what you said but I want to recover the data on the drive. -
first make sure it's spinning. power it down, wait a minute power it back up while touching the top cover. motor spin up? slight vibration, and motor noise?
if so you might go to the drive manufacturer's website and get their drive diagnostics software and run that next.--
This is why I made my suggestion. I know that you want to recover the files, but unfortunately that may not be possible. If you continue to try and recover, be very careful that anything you do does not write to the drive and cause further corruption. Good luck.Originally Posted by Squid_uk"I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
Definitly IS spinning! You can hear and feel it when its plugged/unplugged! I will have a look for a diagnotics test!Originally Posted by aedipuss
It's been several years since I had to do this. The last time I used a program called Lost & Found from Powerquest. The program and company no longer exist. I believe they were bought by Symantec.Originally Posted by Squid_uk
You got the wrong adapter. USB is NOT the way to go.
You want a STANDARD laptop drive adapter that lets you treat the drive as a STANDARD desktop drive so that you can use STANDARD tools on it. You are making your life more difficult.
The drive has recognized previously, may well only be running for short periods. USB connection introduces an extra complication which prevents using many options.
The adapter simply integrates the missing power connector. Otherwise you have a normal drive. Would work for Linux, XP install, HDclone, Chkdsk, many others. Probably also the manufacturers diag tools mentioned, though those might work under USB. I Never, Ever, use such a connection for a possibly failing drive.
Windows Vista laptop always starts up to blue screen of death.
By Super Warrior in forum ComputerReplies: 5Last Post: 26th Mar 2011, 19:56 -
Blue Screen of Death (BSOD)
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 4th Dec 2009, 05:31 -
Inspiron B130 ... Blue Screen of Death
By lacywest in forum ComputerReplies: 2Last Post: 30th Nov 2008, 08:30 -
Blue Screen Of Death
By Squid_uk in forum ComputerReplies: 15Last Post: 31st Mar 2008, 15:35 -
Blue Screen of Death while converting .avi to DVD
By robwbright in forum ComputerReplies: 7Last Post: 5th Oct 2007, 21:53
