I have just bought a Samsung DVD-R149. I have used your MultiRegion Hack code and that seemed to work. But when I try to record a NTSC video tape onto DVD I get the following error message:
"You cannot record. Please check the TV system"
There is also interference on the bottom 20% of screen. (this is not present if I just play the video through the switched off DVD player)
The video player is a Grundig GV9110
The most likely issues are
1. Your player is not outputting true, native NTSC, but rather psuedo-PAL, or PAL60. Most recorders will not record this signal correctly, if at all
2. Your recorder needs to be told that the incoming signal is NTSC. I know my Pioneer works like this.
3. Your recorder simply can't record NTSC signals at all.Read my blog here.
Thanks Guns1inger
How do I tell the recorder what the incoming signal is? The instruction manual needless to say does not include this!
Failing that can you recommend a DVD recorder that will copy NTSC tapes.
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
Remove video tape copy protection
By Mållgan in forum Capturing and VCRReplies: 15Last Post: 19th Nov 2008, 06:25 -
Can anyone recommend a NTSC capture + video card based on this criteria?
By Rein Engel in forum Capturing and VCRReplies: 7Last Post: 5th Feb 2008, 07:25 -
How much longer can tape-based HDV hang on?
By Ollie6431 in forum Newbie / General discussionsReplies: 18Last Post: 1st Feb 2008, 10:55 -
Do you prefer tape based camcorders or hard drive units?
By yoda313 in forum PollsReplies: 33Last Post: 6th Aug 2007, 21:40
