Right,
the program works now, thanks again (!), I reduced a file successfully to 700kb.
The original file (private stuff of course) is in a folder on my desktop.
It has two sub-folders, the usual Audio_TS & Video_TS.
The format seems to be like that on commercial DVDs, so "something.VOB", coming in four seperate bits like "something_1.VOB" etc.
When I start this with VLC, I simply drag the whole folder in.
That is what I did with ffmpegX (o.o.9k), I selected that folder.
The settings I left as they came, I never changed anything in the program.
It created an avi file of the correct size (700mb),
but:
No sound &
the proportions contorted.
Questions:
1. How to get it incorporate the sound? (The Audio_TS is empty, but the movie has sound!)
2. How to make it have the same proportions of length and width as the original?
Thanks, help appreciated!
Jens
The Audio_TS folder should be empty for a standard DVD -- the folder is there to support an audio-only DVD (think of it as an audio CD with unusually long play time). In a normal DVD, the audio is combined ("multiplexed") with the video within those .vob files.Originally Posted by jburkhardt
In converting with ffmpegx, there is an option for selecting the audio track to be converted. Ffmpegx will default to some particular track, but it's possible that the track either contains no audio, or has audio in a format that ffmpegx can't handle. When you drag the file to be converted onto ffmpegx, what does ffmpegx say about what the audio is?
As for the proportions ("aspect ratio"), ffmpegx will not always select the right one automatically. You may have to override its choices manually.
For converting from DVD into Divx or Xvid .avi, you may wish to consider using D-Vision3. It has a less confusing interface, and it is smarter about selecting appropriate audio tracks and aspect ratio. In general, it is the closest to a "one-click" converter as exists. It is freeware, so it won't cost you anything to try it to see if it serves your purposes. No criticism intended of ffmpegx, but its flexibility is both its strength and weakness -- it can do so many things that the user has to fiddle with quite a few parameters to get the desired results. D-Vision focuses on just the conversion from DVD to Divx (or Xvid), and so it is correspondingly simpler to operate.
Good luck with whatever you choose!
Is there any particular reason for choosing 0.0.9k over the more recent 0.0.9x or 0.0.9y? You're not running Mac OS X 10.2, do you? Because that's the only reason that I can think of to use version 0.0.9k.Originally Posted by jburkhardt
ffmpegX has loads of options. The presets try to set a lot of options correct, but I always check to verify if it is set for the results that I want to get. Not changing a setting is like not making a choice for the ouput.Originally Posted by jburkhardt
Normally ffmpegX handles the most common types of audio from VIDEO_TS folders just fine, using a mencoder preset (which you did, as that preset is default). To find out why it didn't work, please enlighten us by supplying details from the left side of the Summary in ffmpegX. It should list what kind out video and audio was found by ffmpegX in your source file. (The text in the light-lime-colored fields is selectable, so you may copy and paste to your browser.)Originally Posted by jburkhardt
Does your source video have an aspect ratio of 4:3 or 16:9? Go to the Video tab an set the desired aspect ratio in the Auto Size select menu. Doing so will change the width and height in the Video Size fields right above it, to conform to the set aspect ratio (proportions).Originally Posted by jburkhardt
Sure, once you KNOW what to do ...Originally Posted by Case
[/quote]Normally ffmpegX handles the most common types of audio from VIDEO_TS folders just fine, using a mencoder preset (which you did, as that preset is default). To find out why it didn't work, please enlighten us by supplying details from ...[/quote]
I made another attempt later, directing it not to the video whole folder, but just to the video_ts, that worked.
I got other problems now though, which have to do with that i simply dont know what all the otions mean ...
like: the converted file does not play the full video length ...
so, i for now try that d-vision thing as suggested above.
thanks.
sorry, i tried three times, cant figure out this thing with the quotes ... yes --- gotta go, has to do like this for now.
I'm very glad to hear that it did the job for you. I use D-Vision all the time for the same purpose, and for the same reasons. I rarely have to override any of its choices (and those rare situations generally involve figuring out which of several mislabeled language tracks is the one I really want; not too hard to figure out).
Enjoy!
Batch "file creation from a text file, Placed into a created directory
By Muther in forum ProgrammingReplies: 5Last Post: 24th Sep 2015, 19:29 -
converting vob to avi or h 264 changes video proportions
By bob apple in forum MacReplies: 2Last Post: 19th Oct 2010, 23:39 -
[SOLVED] Maintaining proportions: gimp - Cinelerra ?
By jdetwile in forum LinuxReplies: 2Last Post: 22nd Mar 2008, 10:51 -
No Sound on DVD Created From Hauppauge HVR-1600 in Windows Media Player
By JimBarbasol in forum Capturing and VCRReplies: 11Last Post: 18th Jan 2008, 23:02 -
Since on Vista, AVIs created only have sound.
By Alain2007 in forum Newbie / General discussionsReplies: 2Last Post: 18th Nov 2007, 19:32
