    Oct 2008
    what program can i use to create a 3:2 pulldonw on a 25 PAL DVD?
    tanks
  2. Member ntscuser's Avatar
    Mar 2003
    DGPulldown
    You have to demux the video first and resize to 720x480, preferably non-interlaced.
    See here for details:
    https://forum.videohelp.com/topic300144.html
    Oct 2008
    ntscuser
    Posted: Nov 01, 2008 13:13
    DGPulldown
    thank you for the reply will try DGPULLDOWN and will come back to post a new reply to see how everything went...
  4. Note that 25 frames per second to 59.94 fields per second doesn't use 3:2 pulldown but rather 3:2:3:2:2. In any case, DgPulldown will generate the correct pattern.
