Hello!
I have recently been having some problems with making a DVD using a DVD-R disc. I successfully burnt my .vob file to the DVD, but it would not play in my DVD player. Any help is greatly appreciated.
PLEASE give us more information, what software are you using and do you just have a vob file?
You can not just burn a vob file on dvdr for example. You must have vob, ifo and bup files in a VIDEO_TS folder. If you don't have that then author your vob file to a dvd using for example dvdauthorgui, guifordvdauthor, muxman and then burn it.
Any SD DVD Player That Plays AVC File?
By wulf109 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Nov 2011, 13:18 -
dvd burning with a single vob file
By rtr720 in forum Authoring (DVD)Replies: 1Last Post: 17th Jan 2010, 04:22 -
Which DVD Player For Under $50 Plays Most Downloaded File Types
By DJboutit in forum DVD & Blu-ray PlayersReplies: 10Last Post: 6th Jan 2010, 15:55 -
Is VLC a fault-INtolerant VOB PLAYER for pre-DVD-burning quality testing?
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 5Last Post: 16th Aug 2009, 21:52 -
Burning an 8gb vob file to dvd??
By skyxx in forum Newbie / General discussionsReplies: 5Last Post: 14th Aug 2008, 18:31
