If that makes any sense - which software would you recommend to, for example, take 5 downloaded music videos, burn them to your DVD and then be able to use your DVD remote to skip to each one?
Currently using Cucusoft AVI to DVD Creator Pro but this seems to default to about 20 or 25 minute splits. If each one of your AVI or MPG files is only a few minutes each, which software would allow you to navigate between the beginning of one file to the beginning of the next without manually fast-forwarding?
Also how, without using editing software i.e. Avid etc, would I be able to take, say, favourite episodes from a DVD set and compile them on to one DVDr?
Appreciate help from anyone who could recommend suitable software that can definitely do both.
1. I would try DVD Flick
2. Use DVD Shrink in reauthoring mode to both cut out clips and make a new DVD, see http://www.dvdshrink.info/compilation.php -
Another option is convertxtodvd, you can set the chapter length to anything (e.g. 5min or 1min, etc...), also you could use each video as a separate title so you could navigate/skip by title.
Okay great, both seem to be able to do the job from first look
Thanks for your help -
Just in relation to this, having cleared adequate HD space I now have tried the trial version of ConvertX to DVD. Problem is, the conversion part took forever (around 4 hrs!) and then when it came to burning the message came up pls put in a blank writable DVD. Tried 3 single layer then 1 dual layer discs - didn't work. It created the folder i.e. the VOB files etc (not sure that my laptop could read them so I think I read them from the ISO files) but it just wouldn't read them, even when I pressed cancel and then instructed it from the main menu 'actions' tab. I was aware that it would put the watermark in the trial version and that's ok but I'm reluctant to pay for the product if it's this slow or unresponsive when burning - any help/advice?
Also the following problem has been going on for a while, in the new year I'm determined to sort it out. I made a film which I had converted from VHS to DVD. I wanted to post it on youtube and got this response from them.
"Thanks for your email! There are far too many variables in that kind of
conversion for me to be able to give you exact directions. I would
recommend searching around on the web for things like "DVD to AVI". You
should find a number of websites with good information and walkthroughs to
get you started. We recommend the MPEG4 (Divx, Xvid, SQV3) format at
320x240 resolution with MP3 audio. Resizing your video to these
specifications before uploading will help your clips look better on
YouTube."
Anyone know the best program again for this and do utube still have a limit on how long your videos can be? Mine's 1/2 an hour so may need to split it. A definitive answer would make my day.
Cheers all -
You can also manually set chapter points anywhere you want to.Originally Posted by poisondeathray
Ok - do you have the full version software too? Just want to know if I'll get those glitches with the paid version?
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
converting multiple avi files to mgeg at once
By killagoob in forum Newbie / General discussionsReplies: 2Last Post: 20th Apr 2008, 04:02 -
Problems converting Multiple .avi files w/ subtitles to DVD
By bwanis in forum MacReplies: 2Last Post: 30th Nov 2007, 13:23 -
Problem when converting DV AVI files to MPEG
By MI6 in forum Video ConversionReplies: 1Last Post: 29th Jul 2007, 14:34
