Hey guys, I just downloaded Avidemux! It's great... but which format am i exporting the videos for youtube to? Or is there a better tool?
And since my video is 44 minutes is there a way to export in slices, each 10 minutes?
Thanks guys
check my blog
http://blog.riccardo-ulpts.com -
Hi,
I use MPEG streamclip, with very good results so far.
The best format for me has been H.264.
You set the quality to 60 or 70%, depending the size and characteristics of the file you want to convert and you end up with a very decent quality file.
I also compress the audio to AAC 160 Kbps.
Good Luck !. -
SUPER and Handbrake are also good options. If you are uploading SD content, check out my YouTube high quality post at:
http://webvideotechniques.com/35/how-to-encode-your-videos-for-youtubes-new-high-quality-option
If you are working with HD and want for YouTube to show the "watch in HD" link, you should refer to my latest guide on encoding for YouTube HD at:
http://webvideotechniques.com/123/bigger-and-better-encoding-for-youtube-hdTake your skills to the next level @
Free simple tool to export sections of videos?
By Maoukiji in forum Newbie / General discussionsReplies: 6Last Post: 19th Mar 2012, 13:59 -
How to export from after effects to youtube? (its just not 'happening')
By Devilsadvocate in forum EditingReplies: 0Last Post: 3rd Mar 2012, 05:14 -
uploading youtube videos - appropriate export format...?
By Bansaw in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2011, 13:30 -
FinalCut Pro settings for YouTube work & export?
By MikeBell in forum Video Streaming DownloadingReplies: 1Last Post: 30th Nov 2008, 11:37 -
best export setting in premire pro CS3 for youtube
By yunakokimama in forum Video ConversionReplies: 2Last Post: 14th Oct 2008, 18:09
