here's the error message i get:
31/10/2008 3:46:22 PM warning Stream #1 (audio) - Codec tag "" unsupported
here's the info on the .avi file:
General
Complete name : C:\Users\***************.avi
Format : AVI
File size : 697 MiB
Duration : 1h 28mn
Overall bit rate : 1 104 Kbps
Writing application : VirtualDubMod 1.5.4.1 (build 2178/release)
Writing library : VirtualDubMod build 2178/release
Video
Format : MPEG-4 Visual
Format profile : Streaming Video@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 28mn
Bit rate : 649 Kbps
Width : 640 pixels
Height : 352 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.120
Stream size : 410 MiB (59%)
Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 1h 28mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 4 channels
Channel positions : Front: L C R, Rear: C
Sampling rate : 48.0 KHz
Stream size : 283 MiB (41%)
Alignment : Split accross interleaves
Interleave, duration : 83 ms (2.00 video frames)
Interleave, preload duration : 500 ms
Language : English
Results 1 to 15 of 15
what version of ConvertXtoDVD are you using........ earlier versions had a problem with AC3 which was rectified in later versions. suggest upgrading to later version
It might be having issues with the non-standard 4-channel AC3 in your .avi
my version of convertxtodvd i thought was pretty recent..... ver. 3.2.1.55
maybe ill try the FAVC -
Do you have .net framework installed?
http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15...DisplayLang=en -
yep microsoft netframework 1.1
when i try to convert the file it says i dont have the right codec or that i dont have avisyth (even tho i do have it installed)
get this.... this file as an .avi has ac3 audio but my divx player doesnt even recognise it and wont play it either. it says i need a direct show decoder to hear the audio with divx player 6.8.2 -
oh the codec ok but i thought that i had that codec when i got divx player and all that.
sence the xvid codec isnt coming up like a link, like the rest of the programs wheres a good spot to get that codec?
edit: after reading my own post i made the link myself.... ok now ill try it all out lets see if i can follow all this.
edit #2: ok FAVC is working away now we'll see later,,,thanks ALOT you were a big help!! thanks all! -
It sounds like FAVC did not finish. Did you close any windows that it opened, specifically a black window with white text in it ? If so, you killed the script before it completed. You can also check the temporary working files folder to see if your encoded files are there. If so, you can author them with any authoring tool to create the DVD. if not, you will have to start again.
Read my blog here.
there was files there yes but they were zero bytes. I did leave the screens open yes... it even let me burn it afterwards but it burned the same think the files but nothing in them...it also didnt say there was an error or anything.
Regardless I was able to convert it a different way. 1st i used nero to convert the 4channel avi to a mpeg2 then i used convertxtodvd to convert it to a dvd.
AVI with DTS wont play - can I convert?
By snadge in forum AudioReplies: 4Last Post: 29th Jul 2009, 10:41 -
trying to convert avi w/ dolby ac3 audio and it wont sync right
By cduval04 in forum Video ConversionReplies: 2Last Post: 14th Jan 2009, 19:40 -
ConvertXtoDVD wont burn movie
By hewhoeatsall in forum Authoring (DVD)Replies: 1Last Post: 14th Dec 2008, 20:58 -
.TS to DVD convert not working with Convertxtodvd
By jcurrieirocz in forum Video ConversionReplies: 12Last Post: 2nd Nov 2008, 23:28 -
Youtube MP4 wont play after using ConvertXtoDVD
By cam89 in forum Newbie / General discussionsReplies: 2Last Post: 26th Apr 2008, 19:27
