I just recently got a western digital wd5000avvs 500 gig sata hard drive. Installed it in my Foxconn NF4SK8AA-8EKRS motherboard and the motherboard does not detect it. In the bios it shows blank on that channel, with nothing hooked up it shows none or you can choose autodetect, But there's no choice, it's just blank. any ideas. Thanks Jay
Not sure but you may need to update the bios for the board to "see" your hard drive.
If you are just wanting to use this drive as storage and not for your operating system you could always buy a cheap pci controller card. Your system is sure to see the drive when plugged into a controller card.Donadagohvi (Cherokee for "Until we meet again") -
Test the HDD on another PC. It's possible the drive is just hosed.
Google is your Friend -
jek,
I've got the same motherboad. If I remeber right, when adding my first SATA drive, I had to enable the faster speed on the drive. The motherboard says it supports both but its not automagic. You do this by adding a jumper to the drive. Check your manual for something like 'server' or '3gb' setting. Don't remember specifics off hand but something along those lines is what got it going.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
I have tried differant cables, all the jumper settings, and differant ports on the motherboard. I will try a differant pc or im going to buy an external case. Thanks for the replys. Jek
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 11:06 -
Hard drive problem
By bballnut in forum ComputerReplies: 6Last Post: 16th Dec 2007, 20:31
