I burned a rmvb format video file to a DVD-R disc to save space on my computer and delete the one in my computer.
I'm using Media Player Classic to play the file.
There is no problem before burning the file to my DVD-R disc. It means I can play the file on my computer without problem.
After I burn the file into a DVD, then play it inside the dvd disc, the sound become choppy.
Then, I try to copy it back to a folder in my computer and play it inside the folder, the choppy sound had gone and I enjoy the video.
But, why the problem occurred when I play the file on my DVD-R disc?
It might be bad media (bad quality disc), or maybe your DVD drive is faulty or set to PIO mode
PIO is an older transfer method that is slow on the IDE channel
Just check the channel in the device manager and make sure the channel is set to DMA (right click my computer, hardware tab, device manager, IDE/ATA controller) Your DVD drive might be connected to your secondary channel depending on your setup, so right click that => properties => advanced settings -
I insert my DVD into USB DVD drive to try. There is no problem when using my USB DVD Drive. Now, I confirmed it is the problem of my internal DVD drive.
Thank you for your reply.
Conversion Question: rmvb file via dvd player
By seifhatem in forum Newbie / General discussionsReplies: 5Last Post: 17th Nov 2010, 12:01 -
No sound upon conversion from RMVB to DVD using WinAVI Video Converter
By kris2099 in forum Newbie / General discussionsReplies: 12Last Post: 19th Sep 2010, 17:28 -
convert rmvb to dvd-no sound?
By sharmine in forum Newbie / General discussionsReplies: 2Last Post: 1st Oct 2008, 04:32 -
Whick dvd player with usb port can play rmvb file?
By haitang in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Jun 2007, 01:31 -
choppy quicktime files on disc
By Shaorin in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2007, 19:03
