Yup, you read that title correctly. I want to know why I'm still able to perfectly fine play back ANY media file on my system when I've spent the last couple of hours trying to uninstall anything even remotely codec related. There should be no codecs left on my system yet for some reason I can still play AVI, MKV, OGM, DIVEX, FLV etc, etc. Anything goes.
I'm on Vista x86 ultimate, using mplayer classic to play back files.
mplayer has builtin codecs. Or do you mean windows media player?
Some media players have their own internal codecs and do not rely upon codecs that are installed into the system.
Should have been more specific. I'm using "Media Player Classic Homecinema". http://sourceforge.net/project/showfiles.php?group_id=170561Originally Posted by Baldrick
As far as I know it does not contain any codecs, but I could be wrong. I'm gonna look into that.
The reason I'm trying to remove codecs is that there was a problem where ffdshow would not be used for playback which resulted in me not being able to use any advanced features. -
mpc homecinema has also builtin codecs/filters. See under View->Options->Internal Filters.
Also, Windows have some build in codecs.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Aha, and I bet it was overriding my other codecs when they were installed which is why I was unable to get the features I was messing with to work. This probably solved the whole problem. thxOriginally Posted by Baldrick
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 14:39 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 18:23 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52 -
Editing AVI, VirtualDub Error, Codecs not working.Can i delete afew scenes?
By UmmAddan in forum EditingReplies: 5Last Post: 23rd May 2007, 05:29
