Anyone recommend a good software for video enhancement of mp4 from an N95 (or similar) please?
enhancement? During playback? Without re-encoding the source, including heavy filtering?
I don't think so. -
OK, so choice of words was not exactly great. What I mean is some software that will increase brightness, cut out some overzealous colouring. Was taken indoors and I need to somehow make it look better.
Most half decent video editors can adjust the brightness, contrast and colour on a video clip, although I don't know how well they will work on an already heavily compressed mp4 file. You may need to encode it to a format that an editor can handle which will lose you some of the little quality it already has.
Can I suggest you use a camcorder next time and use the N95 for what it was designed for, making phone calls.... -
Richard_G, we don't have always a camcorder with us, but we always have our mobile phones. Your suggestion sounds more like irony in this case, even if that is not your intention.
coolchrisyorkshire, what you wish to do is to process your source. There is no way to do this automatically with a software. You have to do it manually.
The best methond IMO, is to convert your mp4 to something that virtualdub understands and use the filters it has. The MSU smart deblocking and neat video filter may help you with this
Alternatively, you can use avidemux direct with your source. It has about the same filters with virtualdub.
Finally, you can use Video Enhancer with the virtualdub filters. It is a commercial program that also upscales any source, using advance technics. It is fast too on multicore CPUs.La Linea by Osvaldo Cavandoli
Originally Posted by SatStorm
Mobile phone footage has been used in worldwide news broadcasts when somebody manages to catch a story as it happens. They don't bother trying to do anything with it, just accept it for what it is.
Video Enhancement
By rckowal in forum RestorationReplies: 20Last Post: 13th Dec 2011, 13:54 -
Video player for nokia N95
By renzord in forum Portable VideoReplies: 2Last Post: 7th Mar 2009, 08:20 -
Converting video for use on Nokia N95
By daiver in forum Portable VideoReplies: 5Last Post: 12th Jan 2008, 02:00 -
Video Enhancement Software
By lazyturbo in forum Newbie / General discussionsReplies: 6Last Post: 25th Nov 2007, 16:14 -
Video enhancement software
By terryxpress in forum MacReplies: 4Last Post: 30th Aug 2007, 11:37
