  1. hi guys im a newbie please dont flame me but here goes
    ive been using guides etc and been making vcd rips and super vcd rips recently and using tmpng encoder i just saw the template to unlock functions and was wondering a couple of things
    a real good looking vcd what bitrate and other settings to make a really good vcd that will fit on 2 80mins cds? i use dvd avi method etc
    and secondly with tweaking with settings can i adjust settings so i can fit a svcd onto 2 80 min cds? normal movie 90-100 min movie 3 cds for 2 hrs or more? and will i inccour problems when burning with nero? max 40 mins or something?
    ok thanks for youre time and please nobody reply with use bitrate calc and thats it!! i need help and u guys are the best for advice thanks see ya
    davidc78@optushome.com.au
  2. for vcd you cant do much(or anything for that matter) with the bitrate if you want to remain within the spec. for svcd encode cbr or multiplass vbr & use a bitrate calculator if you want to make damn sure your project will fit. nero may complain about a number of things, but if you know what you're doing it wont actually prevent you from doing anything
  3. With 80 min. CDs, SVCD:
    - 45 min video, 2350 Kbits/s Video, 160 Kbits/s audio CQ_VBR 90-100
    - 50 min video, 2150 Kbits/s Video, 160 Kbits/s audio CQ_VBR 70-80
    Burn a few CDs and try...
