I have just bought a leadtek PxDVR3200 H and everything works fine except for compent input. I am trying to hook my xbox 360 up to it in High definition.
The only problem is that i cant actually turn the quality up to highdef (720p) on the 360 as it wont come through. Also while it it is on 480p it comes through as a split screen. As in there are two instances of the game on the screen one on the left and one on the right with a black bar down the middle.
This problem however goes away if the xbox cable is switched back to just TV and not HDTV. although this does not allow high def output.
This is a picture of what it looks like with the xbox cable on HDTV:
http://img112.imageshack.us/my.php?image=image10311009componentwz3.jpg
Any information would be great
Alex
	It only support 480i with compent input it had do with on board MPEG2 encoder which can't do 480p, 720p nor 1080i/p
 You want High-Definition video recorder you need look at Hauppauge HD-PVR
  Trying to find Capture Card - w/ Component inputBy tS_veXed in forum Capturing and VCRReplies: 63Last Post: 21st Nov 2008, 08:08
  Has anyone seen the SD component input to h.264 Blackmagic Video Recorder?By edDV in forum Capturing and VCRReplies: 0Last Post: 18th Jul 2008, 21:27
  What is a good DVD Recorder that has Component and/or HDMI Input(s)?By KingKRool2002 in forum DVD & Blu-ray RecordersReplies: 37Last Post: 26th May 2008, 21:08
  DVD Recorder that accepts HDMI or Component inputBy AuditSup in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th Aug 2007, 02:39
  Capture card with Component (RGB) Input and 16:9 SupportBy edt in forum Capturing and VCRReplies: 21Last Post: 27th Jun 2007, 10:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
