We have 2 Tv's that say HD TV monitor I am pretty sure they have no reciever in them as when we got them the price tag on the ones that had a receiver was $300 more I have Dish and don't plan on paying the extra $$$ to watch tv shows in HD and from my understanding I won't need to purchase that converter box we are supposed to need this Feb because we have Dish. my question is if I buy a Blue ray DVD player can I watch Blue ray discs on our HD monitor tv's or will I still need to upgrade our TV's
Check if your tv has an HDMI input. If it does than you're all set.
If it only has component or composite you can still use it. However they will probably eventually fully institute hdcp and then you will only be able to use hdmi for a bluray connection.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
HDMI->VGA: http://www.curtpalme.com/HDFury.shtmOriginally Posted by toolady
HDMI->Component: http://www.curtpalme.com/HDFury2.shtm
PC or monitor?
By Jomapil in forum ComputerReplies: 11Last Post: 16th Oct 2009, 11:08 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43 -
PC monitor as a TV?
By Lee82 in forum ComputerReplies: 5Last Post: 20th Feb 2009, 10:28 -
Use DV as second monitor?
By boyerama in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 02:38 -
Monitor
By JonathanK in forum AudioReplies: 2Last Post: 13th May 2007, 17:15
