Hi all
I have Ulead videostudio 11 plus, and a sony DCR-DVD92E PAL video camera, I've tried to insert video footage (VTS files) into the timeline or library and it doesn't let me, I did find an article saying that the files need to be inserted by going to start>my computer>DVD drive and going into the video TS folder to drag the VTS files to the timeline, this still didn't work.
My next option was to convert the files to another format (I tried MPEG) these were then possible to insert to the timeline, but once I had edited my project and made my new DVD (VTS files) the footage was not as good as the original, and I could make out block on some of the frames,
The imported files (VTS files) were 720 x 576 and the converted files (MPEG) were 720 x 576 as well
Is there a way I can get the files into the timeline or a way a can convert the files with out loosing quality?
I have posted this in both the editing and converting section
Any Help is welcome!
Yep, because it wont reconvert the video as avs and magic probably did.
Thanks Baldrick
I found a link on this site, installed VOB2MPGv2.5 imported files etc and the MPEG files are of much better quality.
The only thing is once I've inserted them into Ulead videostudio and play the project, it jumps frames by upto 10 frames????
The link from which I got the VOB2MPGv2.5 said about downloading .net framework 2.
When I looked into this it didn’t say it was supported by Vista, should I download this anyway?
Newbie wanting to capture/re-author DVD from old and new sources...
By archaic0 in forum Newbie / General discussionsReplies: 4Last Post: 18th Sep 2009, 17:49 -
Something faster than ULEAD Videostudio SE DVD?
By snafubaby in forum Authoring (DVD)Replies: 3Last Post: 2nd Mar 2009, 01:11 -
Newbie wanting help?
By Mark75 in forum Video ConversionReplies: 1Last Post: 30th Oct 2008, 16:13 -
Audio not working in Ulead VideoStudio 8.0 SE DVD
By darts44 in forum AudioReplies: 9Last Post: 23rd Jul 2008, 08:54 -
Ulead VideoStudio 9 Blurry MPEG encoding
By kevluigi in forum Newbie / General discussionsReplies: 6Last Post: 5th Jun 2007, 02:38
