Hello,
I am converting the following avi script to a DVD but it is getting to the sound part of the encoding and is coming up with error cannot find PCM audio track:
LoadPlugin("E:\Program Files\AviSynth 2.5\plugins\QTSource.dll")
v1=QTInput("E:\My Videos\CCMP 10-18-08\100_2670.mov",color = 2, quality = 100, audio = true, mode=2).Fadein(10).AssumeFPS(29.970000)
v2=QTInput("E:\My Videos\CCMP 10-18-08\100_2671.mov",color = 2, quality = 100, audio = true, mode=2).Fadein(10).AssumeFPS(29.970000)
v3=QTInput("E:\My Videos\CCMP 10-18-08\100_2672.mov",color = 2, quality = 100, audio = true, mode=2).Fadein(10).AssumeFPS(29.970000)
v4=QTInput("E:\My Videos\CCMP 10-18-08\100_2673.mov",color = 2, quality = 100, audio = true, mode=2).Fadein(10).AssumeFPS(29.970000)
alignedsplice(v1,v2,v3,v4)
ConvertToYV12(interlaced=false)
ConvertAudioTo16bit()
Similar coding worked for the first 2 video to go on the DVD. Any suggestions or helpful tips would be appreciated..
Thanks in advance..
Results 1 to 9 of 9
You can try converting the audio in the quicktime files to another format. MpegStreamclip should work pretty fast. Also, if I recall there's a "use DirectshowSource" checkbox on the advanced tab of FAVC. You can try that.
Hello,
I am not sure on the first part how to incorporate that into the coding, as I am very new at this and still learning by trying.
As for the use directshowsource, it is use directshowsource for avi instead of avisource. Since I am not use avisource, would this have an effect?
Thanks for the help... -
You have to determine what your source files are. By the code you posted above, they look like Quicktime .MOV files. That means you have to convert them a certain way. DirectShowSource should work with that file format.
Hello,
Ran into another problem with the mpegstreamclip, everytime I open a video it crashes in XP sp 3 using quicktime 7.3, any ideas on what is causing that?
Thanks in advance -
That's probably the same reason why FAVC is struggling with converting those files. Your source files might be messed up in some way.
Only thing I can think of (and it might not work) is to remove Quicktime and install QuicktimeAlternative . It might be more forgiving. -
Hello,
Thanks for the advice. I did get the quicktime alternative and now mpegsterclip is working. I am trying to reencode the code above just as it is to see if it works. If it does not work what else should I try?
Hope to hear from you soon... -
Hello,
I truely thank you. I did encode it while I was out tonight and it worked with no gliches. So, now I am trying the entire night of racing to put on to a DVD.
Thanks again...
error FAVC
By arnerob in forum Newbie / General discussionsReplies: 0Last Post: 12th Jul 2011, 11:28 -
FAVC envoder error
By KnightHeart in forum Video ConversionReplies: 4Last Post: 13th Jan 2010, 17:45 -
Error with FAVC
By magikero01 in forum Authoring (DVD)Replies: 10Last Post: 28th May 2009, 11:42 -
FAVC is Unable to process the following - Error
By tim_ver in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2008, 19:19 -
FAVC error code
By drz400 in forum Authoring (DVD)Replies: 10Last Post: 10th Oct 2008, 16:18
